My QA manager created this nice dashboard showing individual pie charts of each of our field releases showing open issues sorted by Priority. Our CEO was the first to point out that the blue slice on release A is blue and it represents Major issues while in release B the blue slice represents Critical issues. I believe the colour selection is based on the size of the slice and not what the slice represents. Is there a Pie Chart gadget where I can hardcode the colour based on its "Statistic Type" (i.e. Priority, etc)?
Hi Brent,
according to http://forums.atlassian.com/thread.jspa?forumID=46&threadID=40355
the PowerReport Plugin should do that (https://marketplace.atlassian.com/plugins/com.valiantys.jira.plugins.reporting )
Best regards
Thomas
As PowerReport has been archived, I think it's fair to recommend Custom Charts here.
https://link.oldstreetsolutions.com/custom-charts-playground
While Atlassian has decided not to consider the JAC ticket for this feature, we thought it was worth the effort.
Custom Charts for Jira is now available on Jira Cloud, Server and Data Center!
This is a simple app that allows you to select the colors of your pie chart, change the order of the segments, and hide segments you don't want to see. Create professional custom pie charts on Jira dashboards that don't look like they've been made in MS paint on Windows 95...
The interactive demo playground shows you how it works without even installing the app: https://link.oldstreetsolutions.com/custom-charts-playground
We're adding new features all the time to this app, so any feedback on how to improve it would be appreciated.
There's also a companion Confluence app that has identical features so you can add high quality custom pie charts to your Confluence pages.
Pie charts would be a great display to have side by side for each project. We would like to use Status but need to be able to select the color of each status in order to be consistent. This should not be hard and the customer should not have to change the code to do this.
This would make the pie chart a useful tool for management to get a quick glance at the statuses of multiple projects with standard colors like red, yellow, and green.
This was posted in 2012, why 7 years later are we stuck with a nearly useless pie chart like something out of the 80s.
Does Atlassian read these threads?
Is there a feature requests issue languishing somewhere?
Wait I found a bunch https://jira.atlassian.com/issues/?jql=type%20%3D%20Suggestion%20AND%20statusCategory%20!%3D%20Done%20and%20summary%20~%20%22pie%20chart%22%20%20order%20by%20created&startIndex=50
Upvote and comment on this one
I'm seeking the same assistance.
It is frustrating to have four pie charts with different colours for same status across all.
PowerReport add-on is not available for Cloud: https://marketplace.atlassian.com/plugins/com.valiantys.jira.plugins.reporting
Bruno + Brent – agreed, this is annoying, no resolution I take it? It makes it basically impossible to compare pie charts
Has this been considered by Atlassian?
Same here - Changing colours as things get closed out is possibly even more annoying than not matching across pie charts. Please allow us to choose colours, or at least a sort order or something for colours?
We need to set colors in a pie chart to reflect tickets by Priority, so that colors always remain the same for the priorities, as follows:
Just started using pie charts on a large programme and the different colours issues is very confusing. Would really like a way to set colours please.
I see you're looking into this too, DJ. Seems to be based on relative sizes. From what I've heard currently a commercial license is needed to modify the gadget code.
It's simple to chose the color of your pie charts in Jira with this confluence add-on.
It's very easy to use the color picker, so your charts can be consistent.
You can even use HEX codes if needed.
Let me know how you get on with it, it should help!
There's even a demo playground to get a feel for it.
It's currently a Confluence add-on, but the Jira only version is coming soon.
We really need this. How soon will the Jira version be available?
Hey Bill, the Jira Server and Data Center version is now available on the Atlassian Marketplace: https://marketplace.atlassian.com/apps/1220925/custom-charts-for-jira
The Cloud version will be launching in September 2019 :)
Is there no chance, that atlassian will fix this issue in the native Jira Pie-Charts for Confluence? Should be no big Deal I guess and I am facing this issue in every Software Company I've worked in.
We're finding this really frustrating too. Devs getting particularly annoyed that "Done" is sometimes blue, or even red. Whilst the more logical green is used for something else.
It also means we can't run comparisons across our development teams - to at least gauge progress through our sprint.
I have the same problem and this is extremely annoying, is there any news about a fix? I am using jira 7.12.1
