Has anyone integrated JIRA with frontrange HEAT Service Management?
Mark Allen September 14, 2015
Our QA team is currently using JIRA as their primary tracking tool.  We would like to have the ability to integrate with the tracking system our Customer Service Team uses and be able to get certain identified items in HEAT also moved/copied/visible in JIRA.  Is there a method/process or plugin similar to the JIRAtoTFS plugin that anyone has used?
Christine Saxon October 10, 2016
Bump
I know HEAT provides and API , how to integrate withJIRA remains the question, anyone able to provide some insight?
John Barkley
January 11, 2016
Have you found a solution. I would be interested in how you solved the problem.
ex
November 17, 2015
Have you guys found any tools to integrate heat and jira? Our team is for the ways to integrate these two tools
Carol Jones
Have you been able to find a solution for this?  Our team is looking to do the same.
