Have an error when add post-function to update a field
Kirill Lastovskiy January 21, 2016
Hi everybody,
I have an error when trying to add new post-fucntion for transition. I want to automatically update Resolution field for Force closed and Closed after testing statuses
Can somebody help me with this?
JIRA v6.3.10
JIRA Suite Utilities
1.4.9
Error 500:
java.lang.IllegalArgumentException: Cannot find expected argument 'fieldValue' in parameters.
Nic Brough -Adaptavist-
January 21, 2016
You don't need the JSU to do this, the "set field" post-function in basic JIRA sets resolution easily.  Have a look at the default workflow - it clears the resolution on re-open.
It`s true if you want to clear Resolution field.
But I want to update value for example to Fixed. We need it, because developers want to see strikethrough on the Issue when they will select Force Closed. For strikethrough we need change resolution field..
January 22, 2016
The standard function that provides "set field to <none>" also provides "set field to <something>", and that's the one I recommended you use.
Your question had JSU errors in it, which makes it look like you have a broken JSU function, and I assumed you were trying to set the resolution using a JSU function, which you don't really need because JIRA has one built in.
Anyway, it now looks like you are using the built-in function.  So the resolution field is actually a red-herring because that's working fine.
The error message you are getting is being thrown by a JSU function.  Could you have a look at the other functions you have on the workflow?  What validators and post-functions have you put on the transition that is failing?
Kirill Lastovskiy January 23, 2016
Hi Nic,
unfortunately I have not reputation at this forum, so I can naswer only twice in 24 hours smile
This is settings of transition that I am trying to modify:
I`ve already updated JSU to the newest version for our JIRA, but it did not resolve the problem
January 23, 2016
Ok, there's nothing wrong there, can you tell us exactly when the error happens?  Is it when you use the transition or when you try to add a JSU function to it?
Kirill Lastovskiy January 24, 2016
It is when I`m trying to add a JSU function to transtition
January 24, 2016
Ok, so when you are editing the workflow and adding the function, when exactly does the error occur?  On saying "yes" to the add function when you've put all the parameters in?  Or somewhere else?  What function are you trying to add and what are the settings you are entering?
In previous comment I`ve added  screenshots with parameters that I`ve tried to put for post function.
  1. Update Issue field
  2. Issue FIeld: Resolution
  3. Field Value: Fixed
And when I click "Add" then I have error 500 sad
January 25, 2016
The problem is that "update issue field" as shown there is a system function, not a JSU one.  So I'm very confused.
Isaac Montes
April 28, 2016
I'm seeing the same issue, when trying to set the post function update issue field to resolution = done. big 500 error described here.
no JSU installed
Kirill Lastovskiy May 31, 2016
With help of my collegues we found a solution smile
First screen, before modifications, when we choose Resolution a name variable changes to "dummyfield", id stay the same "assignee" and value is "-1" not selected:
If you want to change Resolution field to Fixed for example, then you need to make changes in this string of code (see screenshot):
For Fixed value will be "1". Then just click add or update and it will change post function
I don`t know if it is a bug or something else.. But I am very frustrat
May 31, 2016
You really shouldn't need to be botching things like that - you should read the log to see why you're getting 500 errors and fix that.
which log?
May 31, 2016
Teh application log - jira-home/logs/atlassian-jira.log
When I am tryind to add post function to update field value i have this errors in the log:
2016-05-31 13:48:44,453 http-bio-8443-exec-3702 ERROR username 828x2027003x2 1fmer8f x.x.x.x /secure/admin/workflows/AddWorkflowTransitionFunctionParams!default.jspa [com.atlassian.velocity.DefaultVelocityManager] MethodInvocationException occurred getting message body from Velocity: com.atlassian.jira.exception.IssueNotFoundException: Issue with id 'null' or key 'null' could not be found in the system
    at com.atlassian.jira.web.action.issue.AbstractIssueSelectAction.assertIssueIsValid(AbstractIssueSelectAction.java:556)
    at com.atlassian.jira.web.action.issue.AbstractIssueSelectAction.getIssue(AbstractIssueSelectAction.java:158)
    at com.atlassian.jira.web.action.issue.AbstractIssueSelectAction.getProject(AbstractIssueSelectAction.java:288)
    at sun.reflect.GeneratedMethodAccessor50475.invoke(Unknown Source)
    at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
    at java.lang.reflect.Method.invoke(Unknown Source)
    at org.apache.velocity.util.introspection.UberspectImpl$VelMethodImpl.doInvoke(UberspectImpl.java:381)
    at org.apache.velocity.util.introspection.UberspectImpl$VelMethodImpl.invoke(UberspectImpl.java:370)
    at com.atlassian.velocity.htmlsafe.introspection.UnboxingMethod.invoke(UnboxingMethod.java:30)
    at org.apache.velocity.runtime.parser.node.ASTMethod.execute(ASTMethod.java:270)
    at org.apache.velocity.runtime.parser.node.ASTReference.execute(ASTReference.java:262)
    at org.apache.velocity.runtime.parser.node.ASTReference.evaluate(ASTReference.java:470)
    at org.apache.velocity.runtime.parser.node.ASTAndNode.evaluate(ASTAndNode.java:106)
    at org.apache.velocity.runtime.parser.node.ASTExpression.evaluate(ASTExpression.java:62)
    at org.apache.velocity.runtime.parser.node.ASTIfStatement.render(ASTIfStatement.java:85)
    at org.apache.velocity.runtime.parser.node.ASTBlock.render(ASTBlock.java:72)
    at org.apache.velocity.runtime.parser.node.SimpleNode.render(SimpleNode.java:336)
    at org.apache.velocity.runtime.parser.node.ASTIfStatement.render(ASTIfStatement.java:106)
    at org.apache.velocity.Template.merge(Template.java:328)
    at org.apache.velocity.Template.merge(Template.java:235)
    at org.apache.velocity.app.VelocityEngine.mergeTemplate(VelocityEngine.java:381)
    at com.atlassian.velocity.DefaultVelocityManager.writeEncodedBodyImpl(DefaultVelocityManager.java:117)
    at com.atlassian.velocity.DefaultVelocityManager.writeEncodedBody(DefaultVelocityManager.java:97)
    at com.atlassian.jira.template.velocity.DefaultVelocityTemplatingEngine$DefaultRenderRequest.toWriterImpl(DefaultVelocityTemplatingEngine.java:146)
    at com.atlassian.jira.template.velocity.DefaultVelocityTemplatingEngine$DefaultRenderRequest.asHtml(DefaultVelocityTemplatingEngine.java:134)
    at com.atlassian.jira.template.velocity.DefaultVelocityTemplatingEngine$DefaultRenderRequest$2.with(DefaultVelocityTemplatingEngine.java:120)
    at com.atlassian.jira.template.velocity.DefaultVelocityTemplatingEngine$DefaultRenderRequest$StringRepresentation.toString(DefaultVelocityTemplatingEngine.java:88)
    at com.atlassian.jira.template.velocity.DefaultVelocityTemplatingEngine$DefaultRenderRequest.asHtml(DefaultVelocityTemplatingEngine.java:116)
    at com.atlassian.jira.issue.fields.AbstractOrderableField.renderTemplate(AbstractOrderableField.java:191)
    at com.atlassian.jira.issue.fields.PrioritySystemField.getEditHtml(PrioritySystemField.java:91)
    at com.atlassian.jira.plugin.workflow.UpdateIssueFieldFunctionPluginFactory.getEditHtml(UpdateIssueFieldFunctionPluginFactory.java:164)  <+2>
    at com.atlassian.velocity.htmlsafe.introspection.AnnotationBoxingMethod.invoke(AnnotationBoxingMethod.java:26)
    at org.apache.velocity.runtime.parser.node.ASTReference.render(ASTReference.java:342)
    at org.apache.velocity.runtime.parser.node.ASTIfStatement.render(ASTIfStatement.java:87)
    at org.apache.velocity.runtime.directive.Foreach.performIteration(Foreach.java:393)
    at org.apache.velocity.runtime.directive.Foreach.render(Foreach.java:316)
    at org.apache.velocity.runtime.parser.node.ASTDirective.render(ASTDirective.java:175)
    at com.atlassian.jira.plugin.AbstractJiraModuleDescriptor.writeHtml(AbstractJiraModuleDescriptor.java:133)
    at com.atlassian.jira.plugin.AbstractJiraModuleDescriptor.getHtml(AbstractJiraModuleDescriptor.java:109)
    at com.atlassian.jira.plugin.workflow.WorkflowFunctionModuleDescriptor.getHtml(WorkflowFunctionModuleDescriptor.java:119)
    at com.atlassian.jira.web.action.admin.workflow.AbstractAddWorkflowTransitionDescriptorParams.getDescriptorHtml(AbstractAddWorkflowTransitionDescriptorParams.java:174)  <+2>
    at webwork.util.InjectionUtils$DefaultInjectionImpl.invoke(InjectionUtils.java:70)
    at webwork.util.InjectionUtils.invoke(InjectionUtils.java:56)
    at webwork.util.ValueStack.findValue(ValueStack.java:417)
    at webwork.util.ValueStack.findValue(ValueStack.java:216)
    at webwork.view.taglib.WebWorkBodyTagSupport.findValue(WebWorkBodyTagSupport.java:62)
    at webwork.view.taglib.BasicPropertyTag.doStartTag(BasicPropertyTag.java:54)
    at org.apache.jsp.secure.admin.views.workflow.addworkflowtransitiondescriptorparams_jsp._jspx_meth_ww_005fproperty_005f5(addworkflowtransitiondescriptorparams_jsp.java:1397)
    at org.apache.jsp.secure.admin.views.workflow.addworkflowtransitiondescriptorparams_jsp._jspx_meth_page_005fapplyDecorator_005f0(addworkflowtransitiondescriptorparams_jsp.java:322)
    at org.apache.jsp.secure.admin.views.workflow.addworkflowtransitiondescriptorparams_jsp._jspService(addworkflowtransitiondescriptorparams_jsp.java:128)
    at org.apache.jasper.runtime.HttpJspBase.service(HttpJspBase.java:70)
    at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
    at org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:432)
    at org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:390)
    at org.apache.jasper.servlet.JspServlet.service(JspServlet.java:334)
    at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)  <+2> (ApplicationFilterChain.java:303) (ApplicationFilterChain.java:208)
    at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)  <+11> (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (XContentTypeOptionsNoSniffFilter.java:22) (AbstractHttpFilter.java:31) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (HeaderSanitisingFilter.java:32) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (IteratingFilterChain.java:46) (DelegatingPluginFilter.java:70)
    at com.atlassian.jira.tzdetect.IncludeResourcesFilter.doFilter(IncludeResourcesFilter.java:39)  <+3> (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (DelegatingPluginFilter.java:70)
    at com.atlassian.jira.baseurl.IncludeResourcesFilter.doFilter(IncludeResourcesFilter.java:38)  <+8> (AbstractHttpFilter.java:31) (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (DelegatingPluginFilter.java:70) (ContextFilter.java:25) (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (DelegatingPluginFilter.java:70)
    at com.atlassian.prettyurls.filter.PrettyUrlsCommonFilter.preventDoubleInvocation(PrettyUrlsCommonFilter.java:38)
    at com.atlassian.prettyurls.filter.PrettyUrlsSiteMeshFixupFilter.doFilter(PrettyUrlsSiteMeshFixupFilter.java:24)  <+3> (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (DelegatingPluginFilter.java:70)
    at com.atlassian.prettyurls.filter.PrettyUrlsDispatcherFilter.doFilter(PrettyUrlsDispatcherFilter.java:60)  <+3> (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (DelegatingPluginFilter.java:70)
    at com.atlassian.prettyurls.filter.PrettyUrlsSiteMeshFilter.doFilter(PrettyUrlsSiteMeshFilter.java:74)  <+3> (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (DelegatingPluginFilter.java:70)
    at com.atlassian.prettyurls.filter.PrettyUrlsMatcherFilter.doFilter(PrettyUrlsMatcherFilter.java:56)  <+3> (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (DelegatingPluginFilter.java:70)
    at com.atlassian.labs.botkiller.BotKillerFilter.doFilter(BotKillerFilter.java:30)  <+12> (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (ServletFilterModuleContainerFilter.java:77) (ServletFilterModuleContainerFilter.java:63) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (SiteMeshFilter.java:66) (SitemeshPageFilter.java:124) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (IteratingFilterChain.java:46) (DelegatingPluginFilter.java:70)
    at com.atlassian.prettyurls.filter.PrettyUrlsCombinedMatchDispatcherFilter.doFilter(PrettyUrlsCombinedMatchDispatcherFilter.java:61)  <+19> (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (ServletFilterModuleContainerFilter.java:77) (ServletFilterModuleContainerFilter.java:63) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (SecurityFilter.java:85) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (BaseLoginFilter.java:172) (JiraLoginFilter.java:70) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (IteratingFilterChain.java:46) (DelegatingPluginFilter.java:70) (OAuthFilter.java:79) (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (DelegatingPluginFilter.java:70)
    at com.atlassian.prettyurls.filter.PrettyUrlsCombinedMatchDispatcherFilter.doFilter(PrettyUrlsCombinedMatchDispatcherFilter.java:61)  <+8> (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (ServletFilterModuleContainerFilter.java:77) (ServletFilterModuleContainerFilter.java:63) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (IteratingFilterChain.java:46) (DelegatingPluginFilter.java:70)
    at com.atlassian.prettyurls.filter.PrettyUrlsCombinedMatchDispatcherFilter.doFilter(PrettyUrlsCombinedMatchDispatcherFilter.java:61)  <+14> (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (ServletFilterModuleContainerFilter.java:77) (ServletFilterModuleContainerFilter.java:63) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (ApplicationDispatcher.java:748) (ApplicationDispatcher.java:486) (ApplicationDispatcher.java:411) (ApplicationDispatcher.java:338) (JiraWebworkViewDispatcher.java:124) (JiraWebworkViewDispatcher.java:104) (JiraWebworkViewDispatcher.java:73) (JiraWebworkActionDispatcher.java:204)
    at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)  <+14> (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (ChainedFilterStepRunner.java:87) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (XContentTypeOptionsNoSniffFilter.java:22) (AbstractHttpFilter.java:31) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (HeaderSanitisingFilter.java:44) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (IteratingFilterChain.java:46) (DelegatingPluginFilter.java:70)
    at com.atlassian.mywork.client.filter.ServingRequestsFilter.doFilter(ServingRequestsFilter.java:37)  <+3> (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (DelegatingPluginFilter.java:70)
    at com.atlassian.prettyurls.filter.PrettyUrlsSiteMeshFixupFilter.doFilter(PrettyUrlsSiteMeshFixupFilter.java:36)  <+3> (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (DelegatingPluginFilter.java:70)
    at com.atlassian.prettyurls.filter.PrettyUrlsSiteMeshFilter.doFilter(PrettyUrlsSiteMeshFilter.java:92)  <+3> (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (DelegatingPluginFilter.java:70)
    at com.atlassian.labs.botkiller.BotKillerFilter.doFilter(BotKillerFilter.java:36)  <+23> (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (ServletFilterModuleContainerFilter.java:77) (ServletFilterModuleContainerFilter.java:63) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (AccessLogFilter.java:103) (AccessLogFilter.java:87) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (XsrfTokenAdditionRequestFilter.java:54) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (SiteMeshFilter.java:181) (SiteMeshFilter.java:85) (SitemeshPageFilter.java:124) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (ChainedFilterStepRunner.java:87) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (IteratingFilterChain.java:46) (DelegatingPluginFilter.java:70)
    at com.atlassian.prettyurls.filter.PrettyUrlsCombinedMatchDispatcherFilter.doFilter(PrettyUrlsCombinedMatchDispatcherFilter.java:61)  <+22> (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (ServletFilterModuleContainerFilter.java:77) (ServletFilterModuleContainerFilter.java:63) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (SecurityFilter.java:239) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (TrustedApplicationsFilter.java:100) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (BaseLoginFilter.java:172) (JiraLoginFilter.java:70) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (IteratingFilterChain.java:46) (DelegatingPluginFilter.java:70) (OAuthFilter.java:79) (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (DelegatingPluginFilter.java:70)
    at com.atlassian.prettyurls.filter.PrettyUrlsCombinedMatchDispatcherFilter.doFilter(PrettyUrlsCombinedMatchDispatcherFilter.java:61)  <+13> (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (ServletFilterModuleContainerFilter.java:77) (ServletFilterModuleContainerFilter.java:63) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (ProfilingFilter.java:99) (JIRAProfilingFilter.java:19) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (AbstractJohnsonFilter.java:71) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208)
    at org.tuckey.web.filters.urlrewrite.RuleChain.handleRewrite(RuleChain.java:176)
    at org.tuckey.web.filters.urlrewrite.RuleChain.doRules(RuleChain.java:145)
    at org.tuckey.web.filters.urlrewrite.UrlRewriter.processRequest(UrlRewriter.java:92)  <+10> (UrlRewriteFilter.java:394) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (GzipFilter.java:82) (GzipFilter.java:59) (JiraGzipFilter.java:55) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (IteratingFilterChain.java:46) (DelegatingPluginFilter.java:70)
    at com.atlassian.analytics.client.filter.JiraAnalyticsFilter.doFilter(JiraAnalyticsFilter.java:41)  <+4> (AbstractHttpFilter.java:31) (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (DelegatingPluginFilter.java:70)
    at com.atlassian.prettyurls.filter.PrettyUrlsCombinedMatchDispatcherFilter.doFilter(PrettyUrlsCombinedMatchDispatcherFilter.java:61)  <+40> (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (ServletFilterModuleContainerFilter.java:77) (ServletFilterModuleContainerFilter.java:63) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (ChainedFilterStepRunner.java:87) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (AbstractCachingFilter.java:33) (AbstractHttpFilter.java:31) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (AbstractEncodingFilter.java:41) (AbstractHttpFilter.java:31) (PathMatchingEncodingFilter.java:49) (AbstractHttpFilter.java:31) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (JiraStartupChecklistFilter.java:79) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (MultipartBoundaryCheckFilter.java:41) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (ChainedFilterStepRunner.java:87) (JiraFirstFilter.java:60) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (StandardWrapperValve.java:220) (StandardContextValve.java:122) (AuthenticatorBase.java:501) (StandardHostValve.java:171) (ErrorReportValve.java:103) (StandardEngineValve.java:116) (AccessLogValve.java:950) (CoyoteAdapter.java:408) (AbstractHttp11Processor.java:1070) (AbstractProtocol.java:611) (JIoEndpoint.java:314)
    at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
    at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
    at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
    at java.lang.Thread.run(Unknown Source)
2016-05-31 13:48:44,480 http-bio-8443-exec-3702 ERROR username 828x2027003x2 1fmer8f x.x.x.x /secure/admin/workflows/AddWorkflowTransitionFunctionParams!default.jspa [jira.hidetimetracking.license.LicenseValidator] LicenseValidator: plugin.hidetimetracking.license.status.invalid..eval
May 31, 2016
I can't see how changing a workflow function would be reading an issue, let alone a null one!  I cant tell what is going on here at all, other than you've got some very broken customisation somewhere.
Isaac Montes
June 16, 2016
I have the exact same issue. I doubt this was caused by a customization, I think an Addon jacked things up but I have no idea which one and how to fix it. since I'm running in safe mode and still seeing the issue
Isaac Montes
June 17, 2016
Look in to {JIRA-INSTALL}/WEB-INF/classes/templates/jira/issue/field/priority-edit.vm or resolution-edit.vm or any of those files that may have been modified restore to the ones JIRA originally comes with. Easier; go to: JIRA-BASE_URL/secure/admin/ViewSystemInfo.jspa and scroll down to Modified Files and look for one of those files modified. You or someone may have modified the file for a specific functionality such as priority per project, resolution per project. etc.
Tim Eddelbüttel
September 26, 2017
I would say the workaround from this JIRA https://jira.atlassian.com/browse/JRA-3821 is the root cause.
September 26, 2017
Yes, I'd agree - someone has applied a broken workaround in that case!
Register today
