Having trouble setting summary with combination of custom fields in post-function of create transition
Sara Wajnberg February 11, 2015
I am trying to do the following:
  • Hide summary from create screen (or at the very least have it prepopulated so users can ignore it - right now all I've been able to do is prepopulate it)
  • Once the ticket is created, populate summary with a combination of 3 custom fields that are required on the create screen ("Member ID": "Member First Name" + "Member Last Name")
I have the following script set up on the create transition post-function (via Script Runner):
import com.atlassian.jira.ComponentManager
import com.atlassian.jira.issue.CustomFieldManager
customFieldManager = ComponentManager.getInstance().getCustomFieldManager()
customField = customFieldManager.getCustomFieldObjectByName(“Member ID”)
customField1 = customFieldManager.getCustomFieldObjectByName(“Member First Name”)
customField2 = customFieldManager.getCustomFieldObjectByName(“Member Last Name”)
memberid = issue.getCustomFieldValue(customField)
memberfname = issue.getCustomFieldValue(customField1)
memberlname = issue.getCustomFieldValue(customField1)
Issue issue = issue;
issue.summary = memberid + “: “ + memberfname + " " + memberlname;
but no matter what I do I can't get it to work. It keeps just creating the issue with the default Summary that I put into the description of the Summary field on the particular field configuration in question.
Anyone have suggestions on what I'm doing wrong/how I can get this to work? Your help would be much appreciated! Thanks!
Mario Günter
February 11, 2015
-> answered.
Mario Günter
February 11, 2015
Hi Sara, my problem is quite similiar to your's - still coding and testing. https://answers.atlassian.com/questions/12266549/custom-script-runner-script---not-working-at-all
Thanks Andrey, the summary field is present on the edit screen. I am new to Groovy and don't know how to incorporate the API you referenced - how would you go about writing what I'm trying to do?
Andrey Kuzmin
February 11, 2015
It will look like this: import com.atlassian.crowd.embedded.api.User import com.atlassian.jira.bc.issue.IssueService import com.atlassian.jira.component.ComponentAccessor import com.atlassian.jira.event.type.EventDispatchOption if (issue != null) { org.apache.log4j.Category LOGGER = log; User curUser = ComponentAccessor.getJiraAuthenticationContext().getUser().getDirectoryUser(); IssueService issueService = ComponentAccessor.getIssueService(); issueInputParameters = issueService.newIssueInputParameters(); issueInputParameters.setSummary("Your new summary"); IssueService.UpdateValidationResult updateValidationResult = issueService.validateUpdate(curUser, issue.getId(), issueInputParameters); if (updateValidationResult.isValid()) { IssueService.IssueResult updateResult = issueService.update(curUser, updateValidationResult, EventDispatchOption.DO_NOT_DISPATCH, false); if (updateResult.isValid()) { LOGGER.info("Updated issue " + String.valueOf(issue)); } else { LOGGER.error("Error validating updateResult"); Map<String, String> errors = updateResult.getErrorCollection().getErrors(); for (Map.Entry<String, String> entry : errors.entrySet()) { LOGGER.error(entry.getValue()); } } } else { LOGGER.error("Error validating updateValidationResult"); Map<String, String> errors = updateValidationResult.getErrorCollection().getErrors(); for (Map.Entry<String, String> entry : errors.entrySet()) { LOGGER.error(entry.getValue()); } } }
James Fishwick November 29, 2016
Since this is impossible to read...
  User curUser   ComponentAccessor.getJiraAuthenticationContext().getUser().getDirectoryUser();
} else {
  Map &lt; String, String &gt; errors = updateResult.getErrorCollection().getErrors();
  for (Map.Entry &lt; String, String &gt; entry: errors.entrySet()) {
} else {
  Map &lt; String, String &gt; errors = updateValidationResult.getErrorCollection().getErrors();
Andrey Kuzmin
February 11, 2015
Hello.
I am using this API in my groovy scripts to update issues in post functions. You also have to keep in mind that summary field should be present on edit issue screen for this to work.
p.s. don't forget to call post function after step "Creates the issue originally"
Upcoming Jira Events
