Help me with the script in script runner
ashok 1234
I need to calculate and display in a dashboard gadget the average time between two custom date fields.
More specifically, in the  project, I want to know the average time (in days) between 'Customer Request Date' and 'Customer Proposal Date'.
Ojase
Create scriptrunner scripted field and use the below code on ocnifguration
import com.atlassian.jira.component.ComponentAccessor;
import com.atlassian.jira.issue.Issue;
import  java.util.Date.*
def customFieldManager = ComponentAccessor.getCustomFieldManager();
def dateFieldObject= customFieldManager.getCustomFieldObject('customfield_id1');
def dateFieldObject2= customFieldManager.getCustomFieldObject('customfield_id2');
if(issue.getCustomFieldValue(dateFieldObject) && issue.getCustomFieldValue(dateFieldObject2)) {
def dateValue=  issue.getCustomFieldValue(dateFieldObject) as Date
def dateValue2=  issue.getCustomFieldValue(dateFieldObject2) as Date
return dateValue - dateValue2
ashok 1234
Thanks a lot !!!
Learn more
