×I have added two separate help text for same field under field configurations of two projects but on click of create issue it works on default load but when I change the project and issue type the help text icons fails to render the text.
How do i work on this so it loads properly in all cases.
Note:Help text are different for different project but for the same field.
Use
<img src="/images/icons/ico_help.png" onclick="AJS.$('#solutionProdFieldHelp').toggle();"/>
instead of javascripts
