Help using a groovy script listener when moving an issue between projects
Blake Jones May 30, 2017 edited
Hi everyone,
We are deploying JIRA across several teams, and I am looking for a way to streamline the process for moving issues between projects. For example, say an issue needs to go from Project A to Project B. Currently, the lead for A has to (or should) set the Assignee to 'Unassigned,' revert the Status to 'To Do,' and then do the move procedure.
I would like to have a listener take care of changing the Assignee and the Status fields, so that the lead only has to worry about moving the issue. This will resolve problems we are having with the Project B team receiving an issue from A but being unaware as it's showing as assigned and in progress with a Project A resource.
Currently this is the code I have in the listener and there are no errors in the log, but the changes are not being saved. I somehow need to use IssueManager.UpdateIssue(), but I can't get it to work. Any help is appreciated:
import com.atlassian.jira.issue.IssueManager
IssueManager issueManager = ComponentAccessor.getIssueManager();
Issue issue = issueManager.getIssueObject(event.issue.id)
log.warn("Event: ${event.getEventTypeId()} fired for ${event.issue} of type ${issue.getIssueType().id}")
if (issue.getIssueType().id=="10200"){
log.warn("Issue type check passed")
issue.setStatusId("2")
issue.setAssignee(null)
} else (log.warn("Issue type checking failed"))
adammarkham
June 6, 2017 edited
I'm assuming your scripted listener is already listening for the "Issue Moved" event.
Your changing the issue object but not saving it back to the database
Your best off using issue service to do this sort of thing as it will also reindex the issue for you. To do this you can use the following example:
import com.atlassian.jira.event.issue.IssueEvent
def event = event as IssueEvent
def issue = event.issue
def issueService = ComponentAccessor.getIssueService()
    // do transition first
    def transitionParameters = issueService.newIssueInputParameters()
    // you'll need to have a valid transition setup in your workflow for this
    // replace with your id
    def transitionId = 2
    def user = event.user
    def validationResult = issueService.validateTransition(user, issue.id, transitionId, transitionParameters)
    if (validationResult.isValid()) {
        issueService.transition(user, validationResult)
    } else {
        log.warn validationResult.errorCollection.errors
    // unassign last
    def updateParameters = issueService.newIssueInputParameters()
    updateParameters.setAssigneeId(null)
    validationResult = issueService.validateUpdate(user, issue.id, updateParameters)
        issueService.update(user, validationResult)
    } else {
A few points to note are that you should replace transitionId with the id from your workflow to transition the issue back to "To Do". You can mark the transition as hidden with a condition if you don't want users to see it.
After it's transitioned the update to unassign will be done.
Let us know how you get on with that.
Blake Jones June 19, 2017
Thanks Adam,  we ended up changing our approach and handling this via the workflow and our integration platform.
