Have made many other attempts since I first posted and made several tweaks along the way, but still no success getting the "If" statement to work. I can populate the 2nd field (Resume Test?) when I comment out the if-statement in the below, but have not found how to make if-statement work.
(1) Temp Resume Type - selection (Resume Assembly, Resume Test, Resume Shipment) - custom Checkbox field
(2) Resume Test? - selection Yes, Radio Button
Need to only populate the Resume Test? = "Yes" if the "Resume Test" is selected for the Temp Resume Type field. The reason is I need this is the Temp Resume Type is a temporary field that could be changed, but we need to make additional actions later if at any time a "Resume Test" was selected.
import com.atlassian.jira.ComponentManager
import com.atlassian.jira.issue.IssueManager
import com.atlassian.jira.issue.ModifiedValue
import com.atlassian.jira.issue.customfields.manager.OptionsManager
import com.atlassian.jira.issue.fields.config.FieldConfig
def cf1 = customFieldManager.getCustomFieldObjectByName("Resume Test?")
def fieldConfig1 = cf1.getRelevantConfig(issue)
def value = ComponentAccessor.optionsManager.getOptions(fieldConfig1)?.find { it.toString() == 'Yes' }
if (['Temp Resume Type']*.value.contains("Resume Test")) {
issue.setCustomFieldValue(cf1, value)
