×Hi everyone,
I have a request from a user who wants automation when creating a "configuration" issue type and the custom field "supplier" has multiple choices to create sub-tasks for each supplier from the multiple choices.
I have created a groovy that works BUT creates only 1 sub-task not multiple according to the choices in the supplier custom field.
Can someone from you give me some advice or can discuss my script (I can share it additionally) to see where I am wrong?
Thank you in advance.
i think that if you share you script it will be more easy for the community to give you some hints or advice
I really don't know how to share it here ...
it doesn't allow me to paste it, can't attach it, so I don't know what to do to share it. Can you advise on how to share it?
May be you could use github to share you code or a screen shot of your code
