Hi, I am unable to find the "stage" field in my project while creating the issues.
Defny September 12, 2017
Hi, I am unable to find the "stage" field in my project while creating the issues. I have added the field while creating the screen but while creating bug issues i am unable to get the stage field
Suhas P
September 12, 2017
Check in Field configuration scheme (used by your project) if the field is visible, it might be hidden. If so then make it visible.
One more case could be check if you have marked field visible from 'Field Config' in the Create Issue pop up screen. Tick mark it if it is not marked.
Defny September 13, 2017
Hi Suhas,
I have checked my field configuration scheme and it is visible. I didnot get your second solution. could u please share more details or screenshot if possible.
Suhas P
September 14, 2017
When you click on create button, it gives a pop up screen. upper right corner, you will see "Configure screen" button. Click on it and see if that field is marked for visible on your screen.
Defny September 15, 2017
Thank you so much. i got it :)
Suhas P
September 15, 2017
Did that work for you?
Tyler Brown
September 12, 2017
Hey Debasruti,
You should check to make sure that the Bug create screen uses the screen scheme that you edited.
Hope this helps,
Tyler
Defny September 13, 2017 edited
Hi Tyler,
Yes i have checked and my bug create screen uses the same screen scheme.
Read the story
