  • Community
  • Q&A
  • Jira
  • Questions
  • Hi everyone.. need to set one default note, not a error Messege display for one custom field..
mustafa sayead August 3, 2023
Hello Team
While creating Task in jira we have one custom field (single select)called "Project type".. generally for some system fiedls (eg: reporter, labels, epic link, reporter) we can able to see some message right, like same I need to set for project type custom field..
Can any one help me to achieve this requriment.
We have JSU,JMWE, SCRIPT RUNNER PLUGINS..
THANKS IN ADWANCE.
Best Regards,
Mustafa
Nic Brough -Adaptavist-
August 3, 2023
It is not clear what you are trying to do here.  Could you explain "able to see some message" more please?
Hi @Nic Brough -Adaptavist-
(On issue create screen)Generally for jira some system fields have some text content right, like the same way I need to configure some text under the custom field ( filed type single select) eg: while adding lables we can able to see some content below lable field same as reporter and epic name field.
Like same way I need to add some text under that custom field
It was done 👍
Thank you for your response
Have a great day
August 3, 2023
You can enter a field description in the field configuration scheme, or under the field's global configuration.
Marc - Devoteam
August 3, 2023
Hi @mustafa sayead
Do you mean a small sub text like: "Start typing to get a list of possible matches." under the reporter field.
If this is your case, edit you custom field and add text in the description field. This will then be shown under the field.
Hi @Marc - Devoteam @Yes,  but not reporter filed we have one single select field called project tyoe.I need small sub test under project type field
I did this one.. thank you so much for your response 🙌
