Hide Create Subtask UI element based on a custom field value condition
VVC
Trying to hide the "Create Subtask" UI element based on a Single Select Custom Field value (CMR Type equals Normal").  I have tried using Script Runner UI Fragments > Hide system or plugin UI element but it is not working as expected.
Am I missing something in this script? The "Create Sub-task" disappeared completely irrespective of any value in CMR Type field.
def issue = ComponentAccessor.getIssueManager().getIssueObject(issue.id)
def customField = customFieldManager.getCustomFieldObjectByName("CMR Type")
if (customField) {
    def customFieldValue = issue.getCustomFieldValue(customField)
    log.debug("Custom Field Value: ${customFieldValue}")
    return customFieldValue == 'Normal'
} else {
    log.warn("Custom field not found: Your Custom Field Name")
    return false
Radek Dostál
October 23, 2024
What is the custom field type?
Just checking because == would only work for text fields and their derivates, but not like labels or options and stuff like that.
VVC
Hi @Radek Dostál - The custom field "CMR Type" type is a single select option. No wonder why this is not working, due to this limitation?
Radek Dostál
October 24, 2024 edited
Due to what limitation? You're checking reference equality between a LazyLoadedOption class and a string.
return "Normal" == customFieldValue?.getValue()
return "Normal".equals(customFieldValue?.getValue())
Either one is fine, you just need to compare string with string.
Like VVC likes this
VVC
Thanks @Radek Dostál . It is working now.
Manoj Gangwar
Hi @VVC Please try the script below.
Changes:
  1. Logic Inversion: Changed the condition to check if customFieldValue is not equal to 'Normal'.
  2. Default Return: Adjusted the return value when the custom field is not found to ensure the UI element remains visible in that case.
if (customField) {
return customFieldValue != 'Normal' // Return true to show the UI element when it's NOT 'Normal'
} else {
return true // Default to showing the UI element if the custom field is not found
VVC
Hi @Manoj Gangwar - Create Subtask menu item option wouldn't display even after changing the "CMR Type" custom field to any value.
SERVER
Learn more
