I would like to hide the reporter name, please let me know whether we can do it.
Reporter name should not be visible to assignee. Only for group of users should be visible.
Hi Kiran,
This isn't possible using the out of the box functionality provided by JIRA, but I believe that you can do this using the JIRA Field Security plugin so I would suggest you check that out as a possible solution for your needs.
All the best,
John
Hi Kiran,
I think this is not possible. Look at this issue: https://jira.atlassian.com/browse/JRA-1330
Field Level security permissions will not be implemented by Atlassian.
Cheers
Thomas
