Hide Tempo Custom Worklog Attributes
Lukas Hennig
October 13, 2020 edited
Hi everyone,
I want to add an attribute to every worklog of each issue and update it in the background. Therefore I wanted to use the "Worklog Attributes" provided by Tempo. Unfortunately users shouldn't be able to see/update the attribute while creating/updating worklogs. I couldn't find any way to hide the Field in the "Log Time" - Dialog.
Since we also use Scriptrunner, which has the ability to hide UI elements using fragments, I wonder if custom worklog attribute fields created by Tempo can also be hidden by Scriptrunner?
If yes, what is the key used by Scriptrunner to find out which UI-Element to hide. The "web location finder" provided by Scriptrunner didn't show any key.
If No, is there an other way to achieve custom attributes linked to worklogs without users having influence on it?
Alexander Eck [Tempo]
October 13, 2020
Hi Lukas,
Scriptrunner has not a support to hide elements in the Tempo worklog dialog. But PowerScripts by Cprime has. It is called Live fields for Tempo
Powerscripts also offers a wide range of other Tempo routines.
Alternativly you could try to inject some Javascript and search and hide the container where the label is "_yourworkattribute_". But this is of course an unofficial and unsupported way of doing things.
BR
Get Certified! ✍️
