Hide a UI element depending on Role
Bastian Stehmann
Hi community,
I am using the "Hide system or plugin UI element" from ScriptRunner Add-On to hide a Link in the UI and it works to hide it for all members of the project.
Is it possible to change the condition so that the link is only hidden for the members of some project roles? I have not found any way to access the roles or the current user yet.
Bastian
Alexey Matveev
April 15, 2018
It would be like this
import com.atlassian.jira.security.roles.ProjectRoleManager
def project = jiraHelper.project?.key
String roleName = "Administrators"
if (project != null) {
def user = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser()
ProjectRoleManager projectRoleManager = ComponentAccessor.getComponent(ProjectRoleManager);
def projectRole = projectRoleManager.getProjectRole(roleName)
return projectRoleManager.isUserInProjectRole(user, projectRole, issue.getProjectObject())
return false
Bastian Stehmann
Hi @Alexey Matveev,
thank you very much for this quick response.
I had to change the line:
to
return projectRoleManager.isUserInProjectRole(user, projectRole, jiraHelper.project)
 because there is not always an issue selected, but now it works great.
Best regards
Bastian
Like • kumar jira likes this
Megan D March 14, 2024
@Alexey Matveev
Hey Alexey, I know this an older post, but I'm unsure of where to put the actual project key that I want this code displayed for. There are many projects on our server and I don't want to mess with their setups.
Bojana Vasic
Hi @Alexey Matveev ,
Could you please tell how to modify your suggested code to have some operations visible for two or three different project roles instead of just "Administrators"? Like visible for project roles "Administartors" and "Service Desk Team".
Many thanks! :)
artiom.s
August 28, 2019
Hi @Bojana Vasic
Try this solution for more than one role:
import com.atlassian.crowd.embedded.api.User
import com.atlassian.jira.user.util.UserManager
def projectRoleAdmin = projectRoleManager.getProjectRole("Administrators")
def projectRoleSDT = projectRoleManager.getProjectRole("Service Desk Team")
Boolean isAdmin = projectRoleManager.isUserInProjectRole(user, projectRoleAdmin, jiraHelper.project);
Boolean isSDT = projectRoleManager.isUserInProjectRole(user, projectRoleSDT, jiraHelper.project);
if(isAdmin || isSDT){
return true;
return false
Best regards,
Artiom
Harsh
March 30, 2023
Is it possible to Hide UI element for a particular status?
Alik
Hi all,
Could you help me please to hide voters from mentioned project in Jira ?
I have tried to hide voters with same code, but it isn't working.
Maybe I am using not correct module ?
I tried this modules
com.atlassian.jira.plugin.system.issueoprations:vote-issue,
com.atlassian.jira.plugin.system.issueoprations:view-voters,
com.atlassian.jira.plugin.system.issueoprations:unvote-issue
kumar jira April 17, 2019 edited
