Sign up Log in
Hide custom field on view screen
Dan27
I need to hide a custom fields (Select List , Text Field , Scripted Field) from all of the users- instead 2 users.
Is it possible to do it on Behaviours? This is my code and it's now working on view screen:
import com.atlassian.jira.component.ComponentAccessor;
def Source = getFieldById("customfield_11507")
def user = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser();
log.warn user
if(user!='dmor(dmor)')
Source.setRequired(false)
Source.setHidden(true)
Jamil Rahimov
February 13, 2019
@Dan27
1.Please try Advanced Edit.
1.PNG //------------------------------------------------------------------------------------------------
2.Then configure your field behaviour:
   - Change hidden to true
   - Add these 2 users to new group and add this group to behaviour.
Sayan Kaiser
There is no advanced edit option on behaviour plugin now
Neta Elyakim
January 22, 2019
You can use this built-in ability (with Behaviour)
1.PNG 2.PNG :
Dan27
Hi @Neta Elyakim ,
I can't do it cause this is not a system field.
Neta Elyakim
January 22, 2019
As you can see in my example- I'm not using a system field.
You don't need to mark the "Shown" (after you've marked it called "Hidden"), look at my marks in the screenshot.
Dan27
January 22, 2019 edited
Hi @Neta Elyakim ,
It's not working... The different user still can see the field.
Like • 2 people like this
Sayan Kaiser
Hi Neta,
This is not working, and the advanced edit option is no longer present on the plugin
