Hide/disable Create button in Create Issue form only for a Project
Deleted user April 29, 2020
We need New issues to be created in project A only from project B via " Create Linked Issue "
Although we could remove " Create Issue " permission in Permission Scheme of Project A, believe this stops creating Linked Issue even from Project B
Is there a way to just hide/disable " Create " button at the bottom of the Create Issue form only when Project A is selected ?
Currently we have Message Text field which warns them not to create, but that doesn't stop users from creating new issue.
Scriptrunner Script Fragments, doesn't seem to provide an option, instead has option to hide Create button from Blue Menu bar across Jira, which is not what required
Just wondering any possibilities.
Any thoughts much appreciated.
3 votes
Payne
April 30, 2020 edited
A ScriptRunner Behaviour can be used to limit issue types based upon certain conditions; in your case, you could leverage it to not offer any issue types. See:
https://www.adaptavist.com/blog/restricting-issue-types-with-scriptrunner-for-jira/
You could use a simplified version of that example and simply state:
issueTypeField.setFieldOptions([])
Doing that will cause a warning to display to the user and prevent them from creating an issue in that project.
Lokesh
Works like charm. Thanks much
Like • Payne likes this
Lacey Also
October 5, 2020 edited
General note: don't be an idiot like me - remember to apply this as a general behavior to an entire project, rather than specifying a particular issue type :)
Diana C December 29, 2020
Does this work with JIRA Cloud at all? Or does this solution work just for JIRA Server?
Like • Julio Rodrigues likes this
Learn more
