Hide fields based on checkbox select
Krithica Gowri Shankar
I have a check box field with 5 values A, B, C, D, E.
Aldo 5 text fields Field1, Field2, .. Field5.
If Option A is checked - Field1 should be visible and other fields should be hidden.
If Option B is checked - Field2 should be visible and other fields should be hidden.
If Option C is checked - Field3 should be visible and other fields should be hidden.
Likewise for other options.
Using behaviour works perfectly when only 1 option is checked.
Now that if i choose Options A and B i want fields 1 and 2 to be visible and other fields to be hidden. And if i choose all options all fields to be displayed. This does not work. How to achieve this? Kindly help.
Krithica
Alexey Matveev
June 4, 2018
It should work with behaviours. Could you provide your script?
Here is the script.
def Checkbox = getFieldById("Checkbox")
def 1= getFieldById("Field1")
def 2= getFieldById("Field2")
def 3= getFieldById("Field3")
def 4= getFieldById("Field4")
def 5= getFieldById("Field5")
log.debug("Checkbox " + CheckboxgetValue())
if (Checkbox.getValue() == "A"){
1.setHidden(false);
2.setHidden(true);
3.setHidden(true);
4.setHidden(true);
5.setHidden(true);
1.setRequired(true);
2.setRequired(false);
3.setRequired(false);
4.setRequired(false);
5.setRequired(false);
else if (Checkbox .getValue() == "B") {
1.setHidden(true);
2.setHidden(false);
3.setHidden(true);
4.setHidden(true);
5.setHidden(true);
1.setRequired(false);
2.setRequired(true);
else if(Checkbox .getValue() == "C"){
1.setHidden(true);
2.setHidden(true);
3.setHidden(false);
4.setHidden(true);
5.setHidden(true);
3.setRequired(true);
else if(Checkbox .getValue() == "D"){
1.setHidden(true);
2.setHidden(true);
3.setHidden(true);
4.setHidden(true);
5.setHidden(false);
5.setRequired(true);
else if(Checkbox .getValue() == "E"){
1.setHidden(true);
2.setHidden(true);
3.setHidden(true);
4.setHidden(false);
5.setHidden(true);
4.setRequired(true);
else
1.setHidden(true);
2.setHidden(true);
3.setHidden(true);
4.setHidden(true);
5.setHidden(true);
Kindly check and let me know what changes are needed to the script
Krithica
Alexey Matveev
June 4, 2018
I would write it like this:
if (Checkbox.getValue().find{it.toString().equals("A")})
Thanks for the help.
I used .contains instead of == it works now.
Tanu
@Krithica Gowri Shankar
Can you help me with small snapshot of your code ?
As mine is not working , in my create scree i see all the fields regardless of my code.
Tanu
Also, wanted to mention, the fields which i am trying to hide based on check box options are multiselect field..
Register here ⬇️
