Hide "Child Issues" section in the issue view
Simon Neuville
Hello!
Since a week, I have noticed a section "Child Issues" in the issue view of my instance. I do not remember configuring this, and would like to blend this out.
I suspect this has to do with "Jira Advanced Roadmaps", but can not find any related setting.
Thank you for your support and kind regards,
Simon
Blaise Rey-Mermet
I had the same requirement and solved it another way. (Note: we run a Data Center JIRA version, so I didn't test it on Cloud version.)
Behaviours only allow you to change how fields behave on issue Create or Update screens, as explained e.g. here https://library.adaptavist.com/entity/basics-behaviours-set-hidden
In the issue main screen, the "Child Issues" is a separate panel, so we can show or hide it with Fragments.
  • In your Admin > manage Apps > SCRIPTRUNNER > Fragments,  create a new fragment and select "Hide system or plugin UI element".
  • Give it a name, e.g. Note: Hide child Issues Panel
  • Hide what: com.atlassian.jpo:jpo-child-issues-web-panel
  • You can add a condition, e.g. I was hiding this panel only for projects of a specific category using:
import com.atlassian.jira.issue.customfields.option.Option
if(jiraHelper.project?.projectCategory?.name == "Project Category X"){
return false // false: hide the panel
return true // else true. show the panel
14-31.jpgThis avoid us to modify any HTML code on the UI.
Craig Flaherty
August 28, 2023
What would the syntax be to hide this panel for multiple projects based on Key?
Ste Wright
March 27, 2022
Hi @Simon Neuville
From what I recall, it might be visible if this Issue Type is above Epic in the Advanced Roadmaps hierarchy.
I'd check if it is as a first step...
  1. Go to Plans > Settings
  2. Choose to view the hierarchy configuration from the left-hand menu
In terms of hiding it, I don't believe there's an option natively. What's the need to hide it, given it is required for Advanced Roadmaps?
Ste
