Hide "Move Option" in certain issuetypes
Nicole Brückner April 23, 2024
Dear community,
I found this functionality for hiding in scriptrunner: Hide UI Element Built-In Script (adaptavist.com)
The suggested one-liner is:
jiraHelper.project?.key in ["SPD"]
This contains the "hide move for project SPD". I just want to exclude issue types. It should not be possible to Move Test & Test Execution issue types. How is the code based on issuetypes?
Thanks in advance.
Nicole
2 accepted
April 24, 2024
Hi @Nicole Brückner
The approach you are using will not work. I am saying this because in the coding you have used i.e.
jiraHelper.projectObject?.issueTypes in ["Test Execution""Sub Test Execution"]
Firstly, if you are trying to invoke the issueTypes object from the projectObject, this will not work.
The Issue Types need to be invoked from the issue itself.
Instead, you need modify your condition to:-
issue.issueType.name in ["Test Execution""Sub Test Execution"]
I hope this helps to solve your question. :-)
Thank you and Kind regards,
Ram
Radek Dostál
April 24, 2024
The "issue" should be in binding variables. So using this works for me:
issue.getIssueType().getName() != "Task"
To make it less error-prone in general I think this should be better as we don't want to do any comparisons against null, if there is no issue in binding (outside issue view for example).
!"Task".equals(issue?.getIssueType()?.getName())
(Negated due to the inverted "Under what circumstances should this link be displayed." but ofc keep/remove the negation as needed.)
Nicole Brückner April 24, 2024
This worked for me super well! Thank you! ;)
Sebastian Krzewiński
April 24, 2024
Hi @Nicole Brückner
Did you try to use issueType.name == "Bug" ?
Seba
Hi @Sebastian Krzewiński ,
Thanks for the quick response. I tried:
jiraHelper.projectObject?.issueTypes in ["Test Execution", "Sub Test Execution"]
But this is not restricting it to the listed Issue Types, it is generally disabling the Move (so everywhere). Error showed:
 2024-04-24 09_10_19-UI Fragments und 19 weitere Seiten - Geschäftlich – Microsoft​ Edge.png
Your suggestion is providing this error message:
2024-04-24 09_12_09-UI Fragments und 19 weitere Seiten - Geschäftlich – Microsoft​ Edge.png
Thanks for the help :)
