Ive used a behaviour to hide summary and set the summary value using JWME Set Field Value Post-function, but it still wont let me create an issues.....
Error
There are fields that are required or in an error state, but the administrator has hidden them or made them readonly using a behaviour.
summary: You must specify a summary of the issue.
Hi @Rob B ,
unfortunately, JWME Set Field Value works after issue creation and, as you know, no issues can be created without summary.
As workaround I suggest to set a default value to summary through your behaviour in the creation screen. After creation your JWME Set Field Value will change Summary.
Another approach is to transfer summary management logic from the JWME post function on your behaviour.
Hope this helps,
Fabio
Hi, thanks for the quick reply. How do i set a value in the current behaviour?
Ive done it! Thats worked perfect! Thank you
