Hiding Application Links i.e. Dev servers from Create Link Forms
Lani Fry
August 6, 2020
When adding links/clones, Users are allowed to select from a list of Application Links through the Server Select Field - jira-app-link
What I would like, is to not have specific servers accessible to be linked to - as those App Links were created to support Administration Migration Tools and not needed for anything else.
Manisha Kharga {Appfire}
August 9, 2020
Hi @Lani Fry
If you want to make a link appear in the application navigator for only specific users, use the Groups box to specify which groups can see the link. To hide the link from all users, select the Hide checkbox (for example, if you want to temporarily hide the link without deleting it entirely).
Please refer to this link for more details:
https://confluence.atlassian.com/adminjiraserver088/layout-and-design/creating-links-in-the-application-navigator
You can do that using a simple javascript embedded into the Announcement Banner. Try using this example: We request you to please try first in your test/staging environment.
<script>
jQuery().ready(function() {
if(jQuery(".login-link").size()>0){
jQuery(".aui-header-before").hide();
</script>
Manisha
