Hipchat notifications and Jira Agile
Sigmund Lundgren October 15, 2013
Jira Agile Simplified Workflow has no transitions other than one. Maybe the hipchat addon should use something else than transitions for the integration. Any solutions other than modifying the work flow and adding transitions?
Jobin Kuruvilla [Adaptavist]
October 15, 2013
Go2Group has a free Hipchat plugin in marketplace that works for workflows as well as issue events. You have the option to pick selected events per project as well.
The plugin also gives an additional "Announcement" feature. See if it is useful.
https://marketplace.atlassian.com/plugins/com.go2group.hipchat.hipchat-plugin
Thanks, that did it
Timothy
October 15, 2013
I believe that Hipchat are triggered from the workflow and no where else.
