Dear JIRA Community,
Does anyone have a query built to run an extract from JIRA to get the following information?
-– Ticket Number
-– Title
-– Date submitted
–- Assigned to
-- Create by
-– Group Assigned To
-– Current and historical status changes from new to closed
-– Date and time of each status change
you can also try our Status History PRO app which has special viewer to create and analyze all the data regarding status changes on your project issues. More details can be found here .
Lime Trees Support Team
Hi @Len Hoffman
You can build a filter with most of these columns to get the information you want for a particular project or subset of a project but getting the history of those issues in one view is not possible. There is a history tab for every issue in Jira where you can get this historical information but to get it in single view is not possible without using an add-on. ScriptRunner for Jira can help you do that - it can fetch the historical changes and display it at one place for you.
Ravi
