Is there an add-on that allows you to easily display & export the changes that were made to an issue's description?
I found this add-on (Issue History Printer) but you can't filter by the type of change.
This add-on displays the information (Description History Tab) but I don't think I can view or export all the description changes for a select number of issues.
