We are adding around 2k issues per day. We don't need to archive them after they are completed. At the moment we can delete them only using bulk but this action allows to remove only 1k issues. Is there any chance to remove all of them at once?
Now we are wasting time by manually deleting issues.
Appreciate your help in this request.
Hi Robert,
I found this, which may help on server but not for cloud. https://community.atlassian.com/t5/JIRA-questions/How-do-you-increase-the-bulk-change-maximum/qaq-p/417702
But if it were me, I would automate. I would write a script using the REST API that would run daily, deleting issues after a certain amount of time after closure.
With ScriptRunner you can configure Escalation Service that can run periodically and remove all the issues found by defined JQL query - see the screenshot of example configuration:
Above example will run every 60 minutes and delete all the issues found by following query:
project = "Jira" AND Status in (Closed, Resolved)
Here is the script that performs delete using "silent" deleteIssueNoEvent method which is perfect for automated bulk deletes:
import com.atlassian.jira.component.ComponentAccessor def issueManager = ComponentAccessor.getIssueManager(); issueManager.deleteIssueNoEvent(issue);
I tested above approach myself and it works.
It works, the issue(s) get deleted, but atlassian-jira.log contains 2-lines of ERROR message for each issue deleted. (Jira 7.5.1) (ScriptRunner 5.2.1)
2017-11-08 01:07:01,166 Caesium-1-4 ERROR admin [c.o.s.c.jira.utils.WorkflowUtils] Errors: {}
Error Messages: [You can not update a null issue.]
2017-11-08 01:07:01,169 Caesium-1-4 ERROR admin [c.o.s.c.jira.utils.WorkflowUtils] Not attmpting transition
Null Issue, I guess because it deleted and nothing to transition.
Any ideas to suppress the messages?
we have exactly the same problem. The Escalation service works great, but still the messages are written to the log-file.
(Jira V8.8.1 ), (Scriptrunner 6.18.0)
Can the messages be turned off or ignored?
It works perfectly and the issue(s) get deleted. Thanks josh!
Does anybody know will it slow down jira if the result of JQL Query will 130K issues? May be there's some way to limit query result?
Please use below code at Escalation service:
Note: If you use the Scriptrunner plugin, above code with escalation service will work.
