Hosting Jira in Azure
Bharath N
June 29, 2021
We are planning to migrate Jira server application (with MySQL DB) to Azure cloud.
The Jira we are using is customized as per the project needs and it is also integrated with other tools like Bamboo, Crucible/Fisheye and SVN .
I want to check if migrating Jira to Azure (along with hooks to Bamboo, Crucible/Fisheye and SVN) is possible .
Kit Friend
June 29, 2021
You can host Jira (Server for as long as licensing allows or DC) on Azure: https://confluence.atlassian.com/adminjiraserver/getting-started-with-jira-data-center-on-azure-938846970.html
