Here is my jira flow
I want subtasks dont go from qa to design review untill all the sub-tasks are in Qa status
I dont want to transition status of parent
Just sub-tasks
Hi Mahsa,
You can't use automation to block transitions or prevent those types of actions from taking place in a workflow. You have to use a Condition or a Validator in the workflow itself.
Hey @Mahsa Rahbani
It would be condition in workflow. "Sub-Task Blocking Condition" is the one you need to look at.
Vishwas
i want to know if i should use automation rules or block condition in jira flow ?
