I am trying ti achieve an automatic estimate upon issue creation is this possible with service desk?
i.e. all issues have an 8hours estimate etc.
Automation Lite (a free add-on) can also do this for you using a simple automation rule.
Never recognized that they have lite version too, thanks for the info. will have a look at it too ;)
Aron, can you explain how to set Estimate field in Jira Automation Lite?
When I create Issue in Jira Automation Lite, the field "Estimate" isn't available.
There are multiple ways but i think all need an addon/plugin.
The Addon Jira Suite Utilities (Suite Utilites for Jira) offers a postfunction to set the value of a field in postfunction of transition.
With custom groovy script for the ScriptRunner plugin you could write a more complex behavior how to set the estimation or simply set the fixed to a value.
You would use both in postfunction of the create transition.
Today only! Share what you’re the most excited about for Team ‘25 or just dance out the beginning of a new quarter with us.
Comment the postOnline forums and learning are now in one easy-to-use experience.
