How Can I change resolutions in flow ?
Radha Chhuttani
Some where when I create task resolution is done and some time is wont done
Alexey Matveev
May 7, 2018
The flow can be cotrolled by post functions. If you want to set the Resolution field then you can use the Update Issue Field post function. If you want to clear the Resolution then you can use the Clear Field Value post functions.
You can find more info on post functions here:
https://confluence.atlassian.com/adminjiracloud/advanced-workflow-configuration-776636620.html
