How I can hide a datepicker field according to another field value ?
Manuel Campomanes
I need to hide or not a "date and hour" field, I try the JS function (http://confluence.atlassian.com/display/JIRA/Displaying+a+Field+Based+on+Another+Field+Selection), but it only hide the text area and not the label and the datepicker.
A schema to explain what I have (left side) and what I need (right side) :
JS code :
<script type="text/javascript">
  source = document.getElementById('customfield_10600');
  if (source) {
      target = document.getElementById('customfield_10601');
      if (source.value == 'Oui') target.style.display='none';
      source.onchange=function() {
          if (this.value == 'Oui') {
                     target.style.display = '';
                  } else {
 </script>
Radek Kantor
March 6, 2012
Hi, take the parent ot an element with id="customfield_10601", should be some <div/> and disable it.
Manuel Campomanes
YEAH !
Just need to modify the target :
 target = document.getElementById('customfield_10601').parentNode;
