How am I able create these type of custom fields in Jira?
Teja
May 1, 2017
I got a requirement that need to arrage custom fields in a row on Create screen.
Is it possible to do that?
Capture.PNG Any suggestions?
AnnWorley
May 1, 2017
You can move the fileds up and down as described in Configuring a screen's tabs and fields but you can't move them side by side as in your screen shot. I wasn't readily able to find an add-on for it, either.
A workaround would be to put the User Picker, then the Select Type, then the next user picker and the pertinent Select Type.
