How are issues ordered on the JIRA Road Map?
wikiwiki August 23, 2012
Go to a project, click the Road Map tab, and then click the down arrow icon to see the trackers in the fix version. I am wondering how these issues are organized...it doesn't look like they are by priority, issue type, or status. Also, I am wondering if there is a way to change the order of how these issues display?
Penny Wyatt (On Leave to July 2021)
August 23, 2012
Hi wikiwiki,
Good question! I couldn't figure it out from observation either until I created a bunch of test issues solely for figuring it out. The answer is, it's sorted by resolution, priority, status, then summary.
Or in diagram form:
Unfortunately this order is hard-coded and isn't configurable.
Penny
(Edited to add: Actually, as I dig deeper into the source, this isn't entirely right. The first sort is by resolution, but it only sorts by whether there is a resolution present or not; not the actual value of the resolution.
So the actual priority of the sort order is:
1) Presence/absence of resolution
2) Priority
3) Status
4) Resolution value
5) Summary )
Thank you so much!!!
Thank you so much!!
