I want to add an Entry here. I wanted to do that with a Web-Section and a Web-Item.
I wrote the following into my atlassian-plugin.xml file, but it does not work and my Navigation bar is disappearing...
<web-section name="myplugin" i18n-name-key="my-plugin.name" key="my-plugin-section" location="admin_plugins_menu" weight="1000">
<description key="my-plugin.description">The My Plugin Plugin</description>
</web-section>
<web-item name="addonitem" il8n-name-key="addon-item.name" key="addon-item" section="system.top.navigation.bar"><!---->
<description key="addon-item.description">The Addon Item Plugin</description>
<label key="addon-item.label"/>
<Link linkid="addon-item-link"/>
</web-item>
<web-section key="admin_handler_config_section" location="admin_plugins_menu">
<label key="Test Section"/>
</web-section>
<web-item key="plugin-admin-config-link" section="admin_plugins_menu/admin_handler_config_section">
<label key="Hello World"/>
<link linkId="handler.plugin.configuration.link" key="plugin-configuration">/secure/admin/plugins/handler/PluginAdminConfigAction.jspa</link>
</web-item>
This worked, but i didn't find out how to link a page that appears in the right window...
