×I like to put defaults text in the description field:
for example:
Steps to reproduce:
Expected results:
Actual results:
Is there a way to do that?
Go to the particular Field Configuration and find the Description field. Click "Edit" and in the description for this field add text similar to the following:
<script type="text/javascript"> if (document.getElementById("description").value == "") { document.getElementById("description").value = "*Steps to Reproduce* \n\n\n\n*Expected Results* \n\n\n\n*Actual Results* \n"; } </script>
This fixed my problem. THanks to everyone who suggested. I decided to stay away from editing the vm file.
Hello Sean,
I tried the same as you suggested, but unable to view default text in the description field.
Is there any requirement of add-on? Please let me know how to add those text?
write this in body of .vm file.
#set($description="yourcontent")
or if u want new line charactersand all,
use this
AJS.toInit(function () {
AJS.$("#description").text(" steps to produce \r \r expedted results \r \r")});
in which case, perhaps edit the .vm file associated with a particular field type?
the edit-xxxxx .vm files are found here on my computer: C:\Program Files\Atlassian\JIRA 4.3.4\atlassian-jira\WEB-INF\classes\templates\plugins\fields\edit
Is this for a custom field you are creating? What is the context? You can edit this sort of thing in the .vm file. I have just created a custom field and have specified name, default values etc so I would assume you could do the same for the description field.
I just want to add the stuff I mentioned previously.
I want the description field to show this text in it.
Steps to reproduce:
Expected results:
Actual results:
You cannot give default text without populating it using Javascript or something. Using Javascript maybe an idea though!.
Another option is to use a description (by editing the description field in the field configuration) that asks the user to enter ther description in the said format.
