How can I auto-export to excel?
Israel Dvorsky March 19, 2012
I would like to auto-export a filter result to excel automaticaly.
eynat bing
January 3, 2013
You can import data to excel with the URL:
http://<<your server here >>/secure/IssueNavigator.jspa?mode=hide&requestId=<<your filter id here>>&os_username=<<your username here>>&os_password=<<your password here>>
Make sure that you shared your filter with everybody and not set it as a private filter.
Rochak Sharma
March 28, 2019
Can you please help with an example of Server to enter in the <<your space here>>
Adam Lee April 16, 2020
I couldn't get this to work.
Midori
December 9, 2014
Save some scripting efforts, and just conveniently create an automation rule with the JIRA Automation Plugin:
  • trigger: use the CRON type trigger (built-in)
  • action: use the Send Excel action (provided by the Excel Automation Plugin)
Read the complete how-to.
hrzadnn September 14, 2014
did it work, @Israel Dvorsky ??
Iain Brown
March 13, 2014
If you don't mind using Google Docs, then this is also an option - it can print index cards for you too http://www.littlebluemonkey.com/blog/automatically-import-jira-backlog-into-google-spreadsheet
Renjith Pillai
March 19, 2012
