How can I automatically open a subtask created under one issue under another issue?
serkan_sezer
Hi Everyone,
we use data center version.
In one project, I can use the Create / Clone issue(s) (JMWE app) function to automatically create an issue in another project and connect them. The function automatically links each other as "report"
Project A
Under the automatic issue created in the other project, I create subtasks with the Create / Clone issue(s) (JMWE app) function.
Project B
issues examples;
Everything works normally so far, but how can I make the linked Project B automatically open as a subtask under the issue when a new subtask is created in Project A?
When the client finds bugs, it will create subtasks for each bugs so How do I ensure that project b is automatically created under the linked issue every time a new subtask is created?
Thank you in advance for your help and guidance.
Carla Ann Rowland
January 17, 2024 edited
Here are is the link to the JMWE documentation: https://appfire.atlassian.net/wiki/spaces/JMWE/pages/461439889/Advanced+configuration+and+usage+of+the+Create+issue+post-function?search_id=4db0aa36-33e2-4baa-a1ff-9aa6ca07acf7
and related topic
https://appfire.atlassian.net/wiki/spaces/JMWE/pages/461472778?search_id=4db0aa36-33e2-4baa-a1ff-9aa6ca07acf7
"Everything works normally so far, but how can I make the linked Project B automatically open as a subtask under the issue when a new subtask is created in Project A?"
Also -- sub-task are considered children of the parent ticket and can have only one parent. "parentage hierarchy" doesn't apply across projects.
So, if I understand your use case: each time a bug is discovered in Project A and Related issue is created in Project B and you want it to be linked issues created in Project B displayed as children in Project A issue they cannot appear as sub-tasks. They can appear as linked issues as you have seen having the linked issues displayed as Reported.
Now if you wanted the sub-tasks created in project B to act like sub-tasks and constrain the actions for the issue in Project A--then you can link them as a dependency; so project A cannot be closed until those dependent issues in Project B are closed.
"When the client finds bugs, it will create subtasks for each bugs so How do I ensure that project b is automatically created under the linked issue every time a new subtask is created?"  Another option is to write an automation rule and use to create and link the issues between the project A and project B. That will require involving your instance administrator to assist in writing a Global "multi-project" automation rule if your are not the project administrator in both Project A and Project B.
