JIRA v6.4
I am trying to set a security level depending on a custom field (Yes/No).
I set a Workflow condition:
"Set issue security level depending on provided condition"
But I don't even know how to see the security level of my Ticket.
I can check It didn't worked. But I can't even manually modify the security of my ticket.
My user is granted to modify security.
Do I have to modify something on my Jira?
Can you help me please?
Franck
Thank you Fidel,
But I can't use JIRA Workflow Toolbox.
And secondly, the feature exists:
image2016-3-31 15:29:24.png
But :
1) it doesn't work
2) I can't reach the field 'security' (to check its value)
Is there a parameter to set?
Regards
Hi Frank,
You can do it using "Set a field as a function of other fields" post-function provided by JIRA Workflow Toolbox using the following configuration:
Note that in this example:
Fidel
Register now
