I want to add another group of (external) users to one of our Jira projects. Before I would like to change the security level of all existing issues within the project from "None" to some more restricted level. A bulk-change does not work because there are issues with closed status.
How can I change the security level even on issues with closed status? If I have to re-open items, maby this can be done on database SQL level?
Hi Tobias,
You can use JJupin for this kind of task, here is a demo snippet(run it from SIL Gadget):
// let's get some issues via JQL string [] issueKeys = selectIssues("project = ABC"); for (string key in issueKeys) { #{key.Security Level} = "Internal"; }
You can do a lot of things with JJupin and its Simple Issue Language(SIL), this is just an easy task. Give it a try :)
Best regards,
Silviu
Interesting, I didn't think that would work because it needs to bypass the "do not edit me" flag on the closed status.
You can do it without any scripting though - edit the workflow, and remove the "do not edit" flag from the status. Or add a transition from "closed" to "closed" and make it go through a screen that includes "security level" (restrict the transition to admins or appropriate people) or even just sets it in a post-function.
Will this cause the change to be logged in the issue history?
Will this cause notification mails to be sent out?
