How can I check in a behaviour script that the "Affects version/s" field is empty?
Gergely Fehér
April 9, 2020 edited
I have an "Affects Branch/es" custom field, and I'd like to force to have only one of "Affects version/s" and "Affects Branch/es" filled - in our system filling none or both is invalid.
A tried the following code, but it does not work:
import com.onresolve.jira.groovy.user.FieldBehaviours
import groovy.transform.BaseScript
@BaseScript FieldBehaviours fieldBehaviours
def branchesField = getFieldByName("Affects Branch/es")
def branchesFieldStringValue = branchesField.getValue()
def versionsField = getFieldById("versions")
def versionsFieldStringValue = versionsField.getValue()
if (branchesFieldStringValue == null && versionsFieldStringValue == null) {
branchesField.setError("brancherror both empty 3")
if (branchesFieldStringValue != null && versionsFieldStringValue != null) {
branchesField.setError("brancherror both filled 4")
I think the problem is the way I checked if they're empty or not. I tried with converting them with .tostring() and comparing with "" and some other ways - but now I think I'm getting lost. Can someone help me?
SITTER Adrien
April 10, 2020
Hello @Gergely Fehér
This is a Groovy script. Groovy is made to simplify this kind of things.
Try this:
if (branchesFieldStringValue && versionsFieldStringValue) {
branchesField.setError("branchesboth empty 3")
if (!branchesFieldStringValue && !versionsFieldStringValue) {
Adrien
Gergely Fehér
Hi @SITTER Adrien,
Thanks a lot, it works!
Siva Indukuri
December 28, 2020
I wrote the below code in behaviour script to check if the field is empty . It is working if it is empty.. however, If i enter something the error is not cleared. Please help ,
I need to clear the error message if there is something in the field.
def loc=getFieldById("customfield_10612")
if (loc) {
loc.setError("Please Enter loc")
Siva Indukuri
December 28, 2020
How do we check if the given field value is text or not in behaviour script in jira
Register today
