it seems that HTML emails contain quite a bit of JavaScript code. Iknow since our users' Lotus Notes 7.0 throws a nasty error.
Is there a way to strip JavaScript from being sent in HTML notifications? ie. I just need vanilla HTML + styles.
it is being tracked as https://jira.atlassian.com/browse/JRA-24559 and while waiting for a fix - I'd like to tweak email output. Will editing Velocity templates help?
thanks
Yes, You can modify your HTML mail templates to strip down the javascripts. You can find the templates at WEB-INF/classes/templates/email/html
Also check out http://confluence.atlassian.com/display/JIRA/Customising+Email+Content
Save your spot
