If a power user created a dozen automation rules with a massive defect, how would I delete them all. I don't want to disable them, I want to delete all of the references. Can I do it using ScriptRunner or do I have to go through the database?
Are you asking about automation for Jira rules?
If so, and there really are only a dozen of them, I recommend:
If you are an Admin user, I suggest that you disable all the automation rules instead of deleting them.
It will not be safe to make any deletion via the database as this could cause other complications.
You can refer to this Jira KB for more information.
Thank you and Kind regards,
Ram
