How can I display empty custom fields
Gavin Jolley
January 12, 2017
6 votes
Nic Brough -Adaptavist-
January 13, 2017
I'm afraid you can't.  JIRA hides empty fields on the issue view to avoid (even more) clutter on screen.
To change it, you have to hack JIRA's core code.
Alexander Post [venITure]
Hi @Gavin Jolley and @Gavin Jolley ,
you are right. Its hardcoded and you are not able to change this by some strange setting. But you should checkout IssueLayout  https://marketplace.atlassian.com/apps/1221618/issuelayout?hosting=server&tab=overview
You can add a alternative Details panel, which allows you to configure to display empty custom fields. Also you can remove status, resultion etc. And it displays all fields such as User Picker.
Dominic Peters July 21, 2021
But the problem still exists if you are in view or edit screen of an issue and delete the complete value and safe. Then the field is hidden.
We use a Group-Picker, but if you want to change the value and it is empy the field ist going away ^^.
4 votes
Chris Moreira
Go Custom Fields -> Configure Custom Field: XX -> Default Configuration Scheme for XX -> Default Value -> Add two spaces here" then click set default. That should do the trick
Brett Flintoff August 22, 2018 edited
I tried this but it's not working for me.
Michael Lasonde
Worked for me, quick work around. Thanks
Ryan Shillington
Yup.  Works in JIRA Cloud.  Nice!
IT System Administrator
March 20, 2019
This didn't work on JIRA server 7.2.3.
Samira Negm April 14, 2019
didn't work for me on a user picker custom field
Andy Janes April 29, 2019
This is a great and simple solution!  For other users reference, this only applied to issues created post-update.
sandeep4774 June 2, 2019
I think two Spaces will work for text field only.
Ajay Kumar July 19, 2019
How to display an empty date field ?
July 19, 2019
See above.
Ajay Kumar July 22, 2019
Yes this very well works for Text field.
But I want to know if I can display an empty date-picker field. In Edit default value, I cannot add empty space Validation error is displayed.
Ivan Orvieto
July 2, 2021
It works visually, but the field is not empty anymore (ie it contains two spaces). If you query for  issues with that field being empty, that would not appear
Victor Galeote Dominguez
March 6, 2023
Exactly, this is the problem that I am facing. Is there a chance to filter by the content of the text fileld (space character)  or by the lenght of the field (in order to filter those shorter than 2 characters for example)?
March 6, 2023
No, see the accepted answer.
Mike Silva August 30, 2024
Hi, updating this thread with the new update since this page was the first one that came up on search. This is in the Field Configuration > Screens Configurations!
https://community.atlassian.com/t5/Jira-articles/Introducing-the-new-Empty-custom-field-configuration-feature-for/ba-p/2379469
anju
April 9, 2020
Can somebody pls share screenshots
Ryan Shillington
Screenshots of what? Spaces? They look like this:
Like 16 people like this
Mechee
Only way I had it work for a checklist field was to do it reverse style, i.e. have them all checked by default and uncheck them as I finish each item.
Jeff Wynne
That's what I've been trying to achieve. I don't think I could live with your workaround :(
Mari Petra January 13, 2017
Fully agree with Nic
Get Certified! ✍️
