How can I do math operations in JQL filters?
Mark_Hornick September 24, 2013
Since JQL does not support mathematical operations, what would be the easiest way (or a practical way) to create a custom filter that does mathematical operations? We are trying to create a filter that reports the percentage difference between the original estimate and the time logged for a task.
It seems that 1) implementing a custom JQL function that computes the calculation or 2) adding a hidden field that does the calculation and then can be referenced using JQL would be two of the more efficient ways to accomplish this task.
Suggestions?
Nic Brough -Adaptavist-
September 24, 2013
I think it's worth pointing out that JQL is not SQL. JQL doesn't actually return any data at all, it simply defines the list of issues that something else is then going to work through.
JQL functions aren't even for returning data, they are more for defining your search.
So, it's a custom field that does the calculation you want really, as fields are display items, not search! I'd follow up what Jamie says.
Pablo Beltran
February 28, 2016
SQL for JIRA does the job. It can transforms any JQL into standard SQL with support to operate with numeric regular and custom fields (+,-, * and / among other mathematical operators and functions).
Then you can show that difference on the Issue Detail View with the SQL for JIRA Custom Fields extension.
JamieA
September 24, 2013
You could use the expression function in script runner. One of the examples in the docs deals with %ages. However that is just for searching for issues.
For reporting, I would imagine there is a plugin already that displays something like this.
Otherwise a calculated field is a good option.
