Hi all,
as far as I know is any resolution which I can define is somehow global. Means once the field need to be set, always all values are listed. I would like to separate the same due to the possible transactions to the status. Means in one transaction is the resolution allowed, in another one not.
Is it in general possible and if yes, what do I need to do?
You can do it with workflow properties. This allows only specific resolutions to be available during the transition. Use the jira.field.resolution.include property.
copy/paste https://confluence.atlassian.com/adminjiracloud/workflow-properties-776636709.html
Even if the link leads me into a 404, the hint with the property helps me to solve the same. So thanks a lot for the quick help!
You need to highlight then copy the address and paste into the url window. Just clicking on it adds junk to the back end. This is a know problem in the forum.
