I can see how to import a file, just don't see how to generate the file from the source project. We are using data center 8.20.6
I'll keep chipping away at it but will keep a lookout for any help.
-Steve Josue
What data are you trying to include in the export for the project? Issue data? Project configuration data?
What problem are you trying to solve with this export? How do you plan to use the exported data?
