How can I export all my issues in Jira?
Deleted user November 15, 2017
I need to export my issues in Jira. How can I do that?
Deleted user June 26, 2019
I got the same problem.
To export 1 issue, it's ok. So I run a filter to find some issues and cannot export these issues in a excel format to share with a third party
RianS
November 15, 2017
I think this really depends on what format you need the export to be in. You can use a filter to find all the issues you want to export and then click on the "export" button on the top right of the Filters view and choose the appropriate export format which includes XML, CSV, HTML with either all the columns in the issue or just the displayed columns in the filter.
I don't have that many selections, but I can export but only 1 at a time. How can I export all my issues? Thanks
Nic Brough -Adaptavist-
November 15, 2017
An xml backup is the only viable export of "all issues".
For up to 1,000 in various formats, search for them and look for the exports on the tools menu.
Like # people like this
RianS
November 15, 2017
XML will give you the most amount of data from the issue including the workflows, customfield ids, and project information. Make sure you aren't in the issue itself, and using the Export from the Filter's results. I've circled the export button in the image below:
