How can I export resource data from Jira Structure
Emma April 22, 2025
I have created a Jira Structure with Gantt + Resources layout. I updated capacity unit and availability in Resources. How can I export all the availabilities and capacities listed in Resources?
Stepan Kholodov _Tempo_
Hello @Emma
It is not possible to export any data related to resources at the moment.
Iif you want to submit a feature request, or if you have questions about anything else in Structure, please reach out to us directly at our support portal.
Best regards,
Stepan
Tempo (the Structure app vendor)
Emma April 22, 2025
Hi @Stepan Kholodov _Tempo_
Thank you for your answer. Is there any other possibility to make capacity planning in Structure? Would you recommend another tool for it?
Sure, if you're on Cloud, you can look into our Capacity Planner app. It is integrated with Stucture.Gantt, so you can have a multilayered solution using both apps in Structure.
Best regards,
Stepan
Like • 2 people like this
Read the story
