×I can add labels to issues on a business project, but they aren't showing on my board. How do I make them visible on the board, and then make it possible to filter the board by label?
No, none of the above answers work for Business Project boards that are not customizable. Unfortunately I believe the only solution is to create a filter and see the issues in regular list mode and not a board. Or convert to a Software Project (not sure if that's possible).
sadly this seems correct; would atlassian like to comment on why this is true? Functionality is stripped out of the business projects boards?
@Kaitlyn Luboff If you are using Kanban Board, and you are either the Board Admin or JIRA Admin, then you can go inside Board Configuration and use "Card Layout" option to show "Labels" field for each card/issue on the board.
In order to filter the board by label, you can create "Quick Filters" inside Board Configuration for each label, using JQL query like "labels = <label-name>".
Please let me know if this solution works for you.
@Taranjeet Singh I'm using a business project template, but looking at all my issues on a kanban project board.
Unfortunately no. I don't appear to have "Board Configuration" in my visible options. I should be the admin for this board, but I don't see it.
@Kaitlyn Luboff When you navigate to your Kanban board for your project, do you see the Board menu on top right and if yes, do you see the option "Configure" in that menu. Please see below for reference:
No, I don't see that :( sounds like I don't have the right access level.
@Kaitlyn Luboff Yes, you need to be either Project Admin or Board Admin in the project, in order to see this menu and configure the board. You can ask your JIRA admin to provide you this required permission.
When creating a 'Classic Business' project they seemed to have stripped out a lot of the functionality that would have been available in the 'Classic Software' projects. This is the reason why you can't see the options outlined by @Taranjeet Singh . I'm looking for the same thing but unfortunately have realised that this option is not even present.
yes, apparently there's no way of filtering by component or label in Jira classic business
Same issue here. What a massive oversight on Attlasian's part. Trying to put together a team project is such a pain right now because we need a board that has the capability of being updated.
