Sign up Log in
How can I find initiative for story or task
sharmila patwardhan June 4, 2020
Is there a way that I can export the initiatives name in excel against a story or task. or some JQL which can fetch me this data
Jack Nolddor _Sweet Bananas_
Are you using porfolio for Jira? If so, do you want to list all initiatives of a given set of stories or task?
sharmila patwardhan June 7, 2020
Yes, using portfolio. But is there a way to extract it as a column against a story or a jql result
Like ludwig.zammit likes this
